Originally Posted By: gathermewool
Will that concoction mix with the brake fluid ever? I'm going to take everything apart and see what I see one more time before my sister comes to pick up the car. It's nicer when it's something obvious...
No it will not mix with the brake fluid as GM actually make something similar "Kluberfluid"GM Part #89022161, just make sure that when You carefully pull open the dust boot & inject the mix that You do not rip the seal
