Hey guys,
I'm working on this mower for somebody at work, and can't figure it out. I've pretty much gave up on it, and will give her one of my "spare" mowers that I have as a permanent replacement (I always seem to have a few "spares" around).
It fires up on the primer gasoline and runs for about a second or so, then quits. It's clear that it's not getting fuel through the carburetor, save for the primer bulb. So I know the primer bulb is good. And there's no choke, so no issue there. This has the carburetor mounted right to the gas tank, and uses a Pulsa-Jet carburetor with the little diaphragm fuel pump. I figured that the diaphragm was bad, not pumping fuel. I put a new diaphragm on it, but no change in how it runs. It will fire up on primer fuel, but won't stay lit.
The carburetor is plastic. I think the material is actually Minlon(R), or so says an old Briggs & Stratton shop manual I have that seems to cover this vintage of engine. There's not much to the carburetor at all, but I feel that there's GOT to be a port that's plugged somewhere. Short of soaking the entire silly thing in carburetor cleaner, I'm not sure what would fix it at this point. A new carburetor won't be worth it, as the mower isn't that valuable at this point (it's a REALLY beat 20" Murray).
But since I'm going to give her one of my spares, I might eventually try to get this to run, just so I have IT as a spare for a later date. What do you all think? Short of replacing the diaphragm, there can't be much more to this thing than a blocked port in the carburetor, right?
