I am not one of the real experts in this forum, but based on what I've read here so far, there seem to be very few ways you could go wrong so long as you keep a reasonable OCI and stick to the vehicle's specifications. Assuming money is no concern, and based on my own (limited and relatively uneducated) experience, I'll make 9 recommendations:
Sythetics: Amsoil, Redline, Pennzoil Platinum, German Castrol, Valvoline MaxLife Synthetic, Syntec, and Mobile 1. (Not necessarily in that order.)
Dinos: Havoline and Castrol GTX
You'll probably get a hundred different answers to your question, but my guess is those are the names you'll see most often recommended. (Not that you should necessariy base the decision on rec. frequency, either.)
As for filters, the ones I see most often recommended are PureOne, Wix, M1, and Motorcraft. Again, it's probably hard to go wrong, except maybe with Fram, which everyone seems rather down on.
None of that is very specific. What exactly does the owners manual specify?
