Originally Posted By: cchase
Part of what I am wondering is, does a magnetic drain plug attract iron particles at the range seen by a UOA? Or rather (because it's obvious they would still be attracted), are they massive enough to overcome the physical retention of the lubricant itself and attach to the drain plug?
Or, are the only particles suitably massive enough to be attracted by magnetic force too large to be detected in a simple UOA in the first place?
Yes, they will attract particles of all size ranges. Iron does not have to be big to be affected by magnets. I took the little bit of the grey film that was on my magnet one time and put it on a slide and took it to work and evaluated it under our high power microscope. I work in the semiconductor industry and we have microscopes that will see very clearly a 1 or two um particle in full color. It looked very cool. It was a while ago when i did it and at that time i was glad i had been using the magnet. Im sure the engine would be fine without it but it cant hurt to have the magnet anyway. I dont have an oil change comming up anytime soon, but the next time i have one, ill try to get some pictures of the paste with a scale beside it so you all can see. It is very hard to get pictures thru this microscope so im not sure if ill be able to do it but we have gotten pictures from it before.
