Originally Posted By: Wilhelm_D
Originally Posted By: Ben99GT
Red Line plainly states that they use polyol ester as the base stock in all of their motor and gear oils, and when questioned they state they use PAO as their additive carrier. They won't get in to percentages at all.
They use phrases such as "fully-synthetic ester formula" and "contain PE Polyol Ester base stocks".
Right off of a quart of RL 5W-30, "Designed to provide the greatest protection by using the highest-quality polyol ester base-stocks and higher levels of antiwear additives (ZDDP)."
Quote:
Okay. A PAO based motor oil with 20% diester or polyolester is a "fully-synthetic ester formula".
I have taken their material to indicate they use a lot of polyolester, but it's not clear that's the base stock.
RL has always made it abundantly clear.
"Rather than cutting costs by blending in petroleum products, Red Line's motor oils and gear oils use superior ester base stocks that provide extreme stability at high temperatures and superior film strength at lower temperatures..."
Quote:
It turns out that you can add a polyolester to a PAO or Group III base and get most of the benefits with better seal compatibility and lower cost.
There are so many different esters out there, some less polar than others, that it's possible to make a 90+% ester based oil that is fully compatible with seals; or so I've read from some of our resident ester engineers. It's such a generalization, like saying "esters" are hygroscopic when we know high molecular weights esters aren't particularly hygroscopic at all.
