Quote:
The oil filter size must not be right for the 51348 as the OE capacity will not fill the car to full when you use a 51348 filter.
Whatever you do, Critic, don't buy a Donaldson. Unless there's some inter-dimensional shift in the cosmos, it would be even worse.
Here's what the 51348 xref's to in Donaldson.
P554408
A - OD (Inches): 2.96
B - Thread Size (Inches): 3/4-16 UNF-2B
C - Length (Inches): 5.53
D - Gasket OD (Inches): 2.76
E - Gasket ID (Inches): 2.39
Relief Valve Setting (PSI): 8-11
Anti Drain Valve (Y/N): Yes
Stand Pipe (Y/N): Yes
Product Type Description: LUBE SPIN-ON FULL FLOW
Primary Application: PERKINS 2654408, MF
Product Group: F
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-10), Various GM, Saturn (85-07), Lexus (90-10), Saab (67-09), Suzuki (86-02), Toyota (88-10), Ford (03-10), Mazda, Mercury (05-10), Yugo (86-89), Various Lawn&Garden, Farm Equip.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
and what does an air filter have to do with this topic anyway
and what does a 3/4-16 thread filter have to do with a modular application?
That all said, I would go with the MC due to price over the spec'd OEM OCI. I would probably choose the WIX if I was going longer.
