Originally Posted By: ps49556n
OK we know there are differences...which one is BETTER??
Very probably they are about the same in performance.
Assuming that the cases don't burst and the bypass valves work, the two measures of "goodness" are efficiency and capacity.
Efficiency measures what percentage of a given particle size is removed in a pass through the filter:
e.g., 95% of 20 micron particles.
Capacity measures how many of these particles can be removed before the filter "plugs" and begins to bypass.
With the common cellulose fibers in most filters they tend to be pretty much alike at a given price point.
