CV Joints Grease ( Repacking )
Ndx
IL
Hi Guys,
What is easily available CV Grease ?
I have Kendall ToughTac with Molly ...
Its recommended for
Kendall L-428 Tough Tac Grease is a premium quality, extremepressure
lithium complex soap grease designed specifically for
use in heavy-duty off-road equipment. It is specially formulated
to provide outstanding protection under wet, muddy, slow
speed, high load, high temperature, and heavy shock-load conditions
So I guess this will not work well ?
K
You should use only grease designed for CV joints. I'm not familiar with L-428, but it doesn't sound like it's designed for the purpose.
AutoZone sells little plastic pouches of CV grease for about $2 each. One was sufficient for a single joint in my friend's Subaru Outback.
Valvoline SynPower specifies it is for also suitable for CV joints.
From Valvoline PDS
Valvoline SynPower Grease is an excellent heavy-duty and multi-purpose automotive and industrial extreme pressure grease. It consists of a lithium complex thickener in synthetic base oil and is fortified with molybdenum disulfide and other quality additives. It provides protection from high loads and may be used over a wide temperature range.
Valvoline SynPower Grease is recommended for use in disc brake and non-disc brake wheel bearings, all-purpose chassis lubrication and constant velocity joint applications.
I don't think that Valvoline is available in Canada...
Thank You Guys
What I've heard of CV joint grease is that it needs to contain a lot of antiwear additives. The CV joint experiences sliding motion, micromotion, and fretting, and needs a lube that protects under these conditions. It also needs to be resistant to heat for inner CV joints for FWD cars, where they operate close to a heat source.
The application is also sensitive to viscosity. It needs to maintain a fine balance. Too high a viscosity and the lube won't creep into the surfaces where lubricant is needed... too low a viscosity and it'll run out. And the lube needs to be shear stable because it can get sheared down rather quickly in application.
I don't have a specific grease in mind. I just know enough to use a CV joint-specific grease.
Thank You again guys...
Not replacing a boot ... clamp just fell off so I'm cleaning it up on the car repacking and putting new clamp :)
I've heard good things about the Valvoline Synpower (and Durablend) greases as well as Red Line CV2 grease for CV repacking.
Hey Guys
I was able to buy only 2 small Bags 85gram each 3OZ is that enough to repack it
any opinions
I think it will be difficult to clean out the joints like that. Even off the car I find it time-consuming to clean them out properly. I'd either remove the driveshaft or just re-clamp it and leave it. Does it look like any dirt got in?
Why not use a grease gun to squirt a bunch of grease into the boot & reclamp it? Assuming it wasn't driven for long without a secured boot, you've little to lose by just doing it like that on the car.
If you're already in there, I would just go ahead and pull the axle, pull the CV joint out, clean it, and re-grease with your grease of choice.
I just replaced a CV boot for a friend on his Subaru, and went ahead and pulled the axle and CV joint then re-greased with CV-2 for piece of mind.
Go ahead and do it right...
That grease got slung all over the place huh?
