I'm currently running Pennzoil Mercon V in my Tribute. I was thinking about changing out to Mobil 1 Syn ATF, but looking at the specs, the Mobil doesn't look all that much better (for more than double the cost).
The Pennz. Mercon V has a pour point/flash point of -67f/385f vs -41f/392f for the Mobil.
I think when the older-spec Mobil 1 was labeled as a true Mercon V, it was a much better ATF than the current "all makes, all models" flavor today.
I'm leaning with sticking with the Pennz. Mercon V and maybe just change it a bit more often.
