Originally Posted By: boraticus
"On premix ratios significantly impacting air/fuel ratio and the need for jetting changes, I've always found this to be an overblown concern."
I'd agree that in most applications, that's correct. Racing engines, on the other hand need every possible advantage to maintain a balance between power and reliability.
A good example to support your claim is the use of oil injection pumps. The amount of oil varies with engine RPM. As the engine spins faster, more oil is injected into the fuel. Oil ratios can vary from as low as 100:1 to 16:1.
Despite that, I believe in keeping the oil on the rich side in premix applications.
What I was saying is that premix ratio should not impact a/f ratio enough to re-jet. Different matter than what the proper oil mix is for a given application. I agree, a little richer than 32:1 is generally better for most hi-po applications. Problem is that although the a/f is not impacted by premix ratio, as you start dumping more premix in the a/f mix detonation can go up (remember when two stroke oils also had octane booster mixed in).
Variable rate oil volume output of some injection pumps can be disaster on long steep unfavorable grades. If the oil pump volume is governed by throttle position, you can do lots of damage going down hills. Think about it - if you premix at 30:1 compared to the pump running ~100:1 at closed throttle with injection pump - what situation would you rather have going down a long steep hill? Old school survival techniques are to blip the throttle, flick on & off the kill switch or tap the choke when going down long hills. A billion years ago we thermocoupled heads and monitored temps in such conditions and things got hot real quick.
