"Low Coolant" light doesn't vanish.
by OpenClose
04/29/16 02:07 PM
Is running "Engine flush" before a change legit?
by OpenClose
04/29/16 01:59 PM
Who Owns A Beater?
by Red91
04/29/16 01:09 PM
What prevents pics from being viewed on posts?
by daves66nova
04/29/16 12:42 PM
QS Filter Miles
by Yup
04/29/16 12:23 PM
Denso Irdium plug at 68k miles
by SHOZ
04/29/16 12:19 PM
Chrome bumpers from RockAuto. Good quality?
by mrsilv04
04/29/16 12:00 PM
Krown Rust Proofing illegal in U.S.
by Warstud
04/29/16 11:49 AM
fixing the t/a
by turtlevette
04/29/16 10:55 AM
windscreen cleaning
by bonjo
04/29/16 10:27 AM
Is it an offence to idle car engine ...
by zeng
04/29/16 10:27 AM
Naturita - Telleride in Early June
by marc1
04/29/16 10:26 AM
Dmax7901, carver1, Handy7rick, sicilien, Crater_77
57738 Registered Users
103 registered (2015_PSD, 01rangerxl, 2009Edge, AandPDan, 04SE, 16 invisible), 1973 Guests and 97 Spiders online.
57738 Members
66 Forums
248218 Topics
#1858983 - 04/15/10 07:39 PM Industrial generator with 1 hour on it..
dirtymudder Offline
Loc: michigan
In the past year. The generator is inside of a heated building and has a block heater on it 24/7. I know it should have been run on load over the past year but that is past history. question is would you change the oil even though it has only one hour on it? By the way when it runs it supply's 480 volt to a 100hp motor.
#1858993 - 04/15/10 07:50 PM Re: Industrial generator with 1 hour on it.. [Re: dirtymudder]
Steve S Offline
Loc: East of IGO
A used oil analysis costs around $30.00 to have done and would tell how the oils condition. What does the manufacture recommend?
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1859038 - 04/15/10 08:38 PM Re: Industrial generator with 1 hour on it.. [Re: Steve S]
MolaKule Offline
Loc: Iowegia - USA
Is it using any oil and has it been run-in?
I assume it's a diesel with about a 100kW output?
Some days I amaze myself. The other days I leave the keys in the Refrigerator. smile
#1859084 - 04/15/10 09:30 PM Re: Industrial generator with 1 hour on it.. [Re: dirtymudder]
bruce381 Offline
Loc: Millbrae, CA
no
#1860482 - 04/17/10 12:20 AM Re: Industrial generator with 1 hour on it.. [Re: bruce381]
D-Roc Offline
Loc: quelque part
Plugged in 24/7...I'd be more inclined to test the coolant.
#1865021 - 04/20/10 06:24 PM Re: Industrial generator with 1 hour on it.. [Re: D-Roc]
dirtymudder Offline
Loc: michigan
Generator has about 2200 hours on it.
#1947404 - 07/09/10 05:56 AM Re: Industrial generator with 1 hour on it.. [Re: dirtymudder]
NesloOne Offline
Loc: Denmark
I feel you do the test, although it will say the oil is still in good condition.
dieselfuel, hydraulicoil, coalmine
#3222658 - 12/20/13 12:34 PM Re: Industrial generator with 1 hour on it.. [Re: dirtymudder]
JR Offline
Loc: Michigan born but my heart bel...
If it only has 1hr on the current fill a uoa will say keep in service. i wouldn't change or sample the oil. it has no use on it.
i would be more concerned about not running it time to time. if it were mine i would run it up to temp under load every 3 to 6 months.
ken
#3223292 - 12/21/13 12:55 AM Re: Industrial generator with 1 hour on it.. [Re: dirtymudder]
Fraser434 Offline
Loc: Chicago
Old Thread, i'm in power generation field service, I see this on a daily basis. Nothing wrong with taking fluid samples and inspecting the generator and transfer switch(s) for proper operation.
CAT put out the option to offer 3 year oil change cycle on CAT diesels C9 and larger in Standby Power application. Can do this by taking quarterly samples and annual filter replacement, still maintain CAT warranty or ESC.
I can tell you a very large telecom company mandates oil changes are to be performed every 3 years or per sample analysis on standby generators.
Still you have issues with engines sitting, injector cups leaking coolant, oil cooler leaking, head gasket or fuel dilution. Just changing the engine oil won't correct these issues and only mask them over for a short period.
Hope this helps.
Edited by Fraser434 (12/21/13 12:59 AM)
