It usually takes me two years to use a tube of grease and I've noticed in that time a lot of the oil will bleed out of the gun. I've seen similar bleed on the wheel bearings of a tractor that sits most of the time. In searching the archives I saw Mobilith SHC 220 mentioned as a low bleed grease. Would this be a good choice for equipment that may be stored months or years between uses?
