Since my little Civic just hit 150,000 miles the other day, I thought about all the maintenance that is coming up and the first is changing out the automatic transmission fluid. I've never done this procedure, but from what I've read I can just put the car on my ramps, loosen the drain bolt, replace drain bolt and then put about 3 quarts in.
At this point, do I HAVE to drive it a short distance and then refill again or can I drive it until my next oil change which is in about 2k miles. I understand that doing a drain/refill won't change all of the fluid but as long as I replace some of it with some fresh fluid, I think it's doing some good. I'm using the Honda ATF, FWIW.
Thanks guys!
Thanks guys!
