cheap upgrade to win 10 from win 7 s/n
by bmwjohn
08/24/16 04:25 PM
trimmer loses power when hot
by motor_oil_madman
08/24/16 04:21 PM
NAPA "GOLD" #1358, 10,080 miles CUT OPEN
by car51
08/24/16 04:01 PM
2016 F-350 diesel factory filter CUT OPEN
by car51
08/24/16 03:37 PM
Craftsman Four Stroke Weed Whacker
by yeehaw1960
08/24/16 03:30 PM
Heat Pump ?'s
by metalone
08/24/16 03:12 PM
Career change advice
by ram_man
08/24/16 02:55 PM
Petro-Canada Motor Oils
by motoroilman
08/24/16 02:45 PM
Cyclists
by Whitewolf
08/24/16 02:19 PM
Wife is livid
by Jarlaxle
08/24/16 01:42 PM
Thoughts on the Honda mowers?
by glock19
08/24/16 01:26 PM
5W30 In a HM Oil Engine
by BlueOvalFitter
08/24/16 01:21 PM
dan0928, basher, Bandita, DaveyJones, OldEuroCarLover
58904 Registered Users
91 registered (440Magnum, 1JZ_E46, 2015_PSD, 09_GXP, Al, 2002 Maxima SE, 12 invisible), 1605 Guests and 8 Spiders online.
58904 Members
66 Forums
253501 Topics
Page 1 of 2 1 2 >
#1850651 - 04/09/10 09:58 AM Is it bad to hit your Rev limiter?
Marukai Offline
Loc: Maryland
I know the Rev Limiter is in the engine ECU to protect the engine from over revving, but is it bad to hit the limiter? Just a FYI to those that are unfamiliar with rev limiters. It's the point when you redline the car to it's redline limit before shifting to the next higher gear. The car will jerk because the computer cuts the fuel to prevent over revving.
2009 Subaru
Impreza 2.5i 5MT
Eneos 5w40 For summer
Eneos 5w30 For winter
Eneos MTF 75w90. Smooth as Butter smile
#1850660 - 04/09/10 10:03 AM Re: Is it bad to hit your Rev limiter? [Re: Marukai]
IndyIan Offline
Loc: Ontario, Canada
Its not great but on some autocross courses guys will bounce off the limiter for a second or two if there's no time to get a shift in before a corner. No harm done.
Don't do it all the time but if your motor is healthy otherwise its not a big deal.
07 Focus ZXW, 5spd manual, 151km VWB 5W30
06 CRV, 5 spd auto AWD, 262km M1 EP 5W30
#1850667 - 04/09/10 10:06 AM Re: Is it bad to hit your Rev limiter? [Re: IndyIan]
FowVay Offline
Loc: Southeastern USA
I think it's bad NOT to hit it. That's why it's there. Enjoy the ride!
#1850687 - 04/09/10 10:20 AM Re: Is it bad to hit your Rev limiter? [Re: FowVay]
Jonny Z Offline
Loc: Austin, TX
it is not as bad as hitting your wife.
02 Camry SE 4 cyl 5sp manual. 120K. Vavoline MaxLife Blend 5W30 + Purolator Classic / Redline MT90 / Michelin HydroEdge
#1850692 - 04/09/10 10:21 AM Re: Is it bad to hit your Rev limiter? [Re: FowVay]
gathermewool Offline
Loc: New England
The redline limit of the motor isn't the same as the rev limiter. IMO, if kept with in the rev limit, motors are usually killed by underlubrication, over heating or excessive time at high load/temp, and cyclic heat loads such as warming up a car too quickly (think rallying your car to work every morning from a cold winter start.)
14 Forester XT
PUPPP + Subie blue filter
08 Civic LX (Auto)
VWB 5W-20 + Fram Ultra (3rd OFI)
#1850725 - 04/09/10 10:42 AM Re: Is it bad to hit your Rev limiter? [Re: gathermewool]
Burt Offline
Loc: texas
It is not bad to hit the limiter once in awhile, but revving your engine that high on a long term basis will cause wear and damage. Just like it does not hurt to use your anti-lock brakes, but they are not intended to be used all the time, it would be hard on the brakes.
2011 RX350 39k miles
2015 Fiesta SFE eco-boost 10k miles
#1850764 - 04/09/10 11:09 AM Re: Is it bad to hit your Rev limiter? [Re: FowVay]
scurvy Offline
Loc: Chicago IL USA
Wholeheartedly agreed. Use the entire RPM range possible. Try not to have it pegged at the limiter all the time but getting it up there occasionally is good for the long-term engine health.
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
#1850774 - 04/09/10 11:15 AM Re: Is it bad to hit your Rev limiter? [Re: scurvy]
KrisZ Offline
Loc: Toronto, Canada
... and if you drive a rotary, it's actually a requirement.
2015 Dodge//Grand Caravan-FF dumped
2006 Mazda 3-135k miles
#1850775 - 04/09/10 11:15 AM Re: Is it bad to hit your Rev limiter? [Re: Burt]
BeanCounter Offline
Loc: NC
Some vehicles, although likely older, can still float valves even with a rev limiter.
AMSOIL
'97 S10 4.3
'07 GXP 2.0T
#1850850 - 04/09/10 12:07 PM Re: Is it bad to hit your Rev limiter? [Re: BeanCounter]
SteveSRT8 Offline
Loc: Sunny Florida
the rev limiter IS the real redline, and there is no way that a stock engine in good mechanical condition will be harmed.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#1850872 - 04/09/10 12:24 PM Re: Is it bad to hit your Rev limiter? [Re: SteveSRT8]
Loc: New England
The redline is the design limit at which damage could occur. The rev limit is not the same. Agreed that there is no way that a stock engine in good mechanical condition will be harmed. Going along with what BeanCounter said, I wouldn't trust my old Subie with 205kmi on'er at rev limit RPMs for very long, though.
14 Forester XT
08 Civic LX (Auto)
#1850893 - 04/09/10 12:46 PM Re: Is it bad to hit your Rev limiter? [Re: Burt]
lexus114 Offline
Loc: Easton, PA
I didnt know it hurt the brakes any ? confused
2012 Mercedes-Benz C300 4matic
2015 Lexus RX350 AWD
#1850917 - 04/09/10 01:07 PM Re: Is it bad to hit your Rev limiter? [Re: lexus114]
IndyIan Offline
Do 5 hard ABS stops from 60mph and open your window. You will smell your brake pads, and you've probably just taken a few thousand miles of life out of them.
#1850941 - 04/09/10 01:29 PM Re: Is it bad to hit your Rev limiter? [Re: IndyIan]
lexus114 Offline
Loc: Easton, PA
Yeah thats funny right ? The only time my anti-lock brakes kick in is in the snow. And that shouldnt be hurting them.
#1850990 - 04/09/10 02:13 PM Re: Is it bad to hit your Rev limiter? [Re: lexus114]
IndyIan Offline
No, the odd ABS usage in snow is probably good to keep things from siezing up. Ice racing with the abs on probably would wear out something in the system eventually.
Page 1 of 2 1 2 >
