My 2006 Toyota Camry is coming up on it's 60,000 mile service interval. The only thing of note for this interval is that the manual states the valve clearances should be checked.
I was talking to my trusted local mechanic about this, and they said Toyota recommends an "audible" check, rather than actually taking the valve cover off and checking the clearances with feeler gauges. While I trust the mechanic's word, I was a bit surprised -- it seems strange to me that one would be able to get any sort of accurate assessment of the state valve clearance (other than being grossly out of spec) simply by listening to the engine.
The Haynes manual details the procedure for taking the valve cover off, rotating the crankshaft to TDC for each cylinder, and measuring clearances with feeler gauges. Nothing about audible checks.
Any thoughts on this "audible" checking? Is the mechanic right? Is my skepticism worthwhile, and should I take the cover off and check things with feeler gauges?
