Originally Posted By: bravo2
Is that the same thing as a "E" rated type tire? I read a lot of tire companies classified theres as a "E". Nitto makes a "E" but i was told it would ride to hard and its a 10 ply and i did not need it, so they ordered the "D" one which is 8 ply, less psi and less max load capable then the "E". Some only offered a E one for the vehicle when search it by make and model.
No, it's not the same. Euro metric is probably a better description of tires without letters in front of the size.
Oh, and your vehicle placard does specify P metric tires. If it has the letter "P" in front of it, then it's a P metric.
I don't recommend replacing "P"'s with "LT"'s and vice versa.
