Chevy 2500 6.0L????
Texas
I just picked up a 2006 Chevy 2500HD with the 6.0L and there is no owners manual.
What is the engine oil spec on these trucks? 5w30 or 10w30?
You may also want to ask how much oil that engine holds.
You can download the manual.... read it online, or order one from your nearest Chevy dealer.
That was fast! Thanks! I kinda figured a heavy duty truck would use a 10w30 or possibly a 40 oil.
Not a gas engine, a diesel, yes.
5w-30 is the spec, but they run just fine on anything from a 0W-30 to a 10W-30.
6 quarts is the sump. Filters are easy to find.
I have run lots of GC in my 5.3L (same engine family as yours). Now running Castrol Edge 10W-30 and its great. PP, Chev Supreme, QS, etc have all been used with good results.
I have the high output version (345hp vs 300) of the 6.0L in my truck ('06 Sierra Denali crewcab) and I just use Mobil 1 5W/30 in winter and 10W/30 in summers. Works for me. UOA's always good too. That 6.0L is a great engine, a little thirsty, but I didn't buy a truck for fuel economy.
I get owners manuals off Ebay. I think people get them from wrecking yards and sell them.
This should help:
2006 CHEVROLET TRUCKS SILVERADO 2500 HD PICKUP 6.0L 8-cyl Engine Code
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......API*
Signature Series 0W-30 100% Synthetic Motor Oil (SSOQT)
SAE 5W-30 Synthetic Motor Oil (ASLQT)
XL 5W-30 Synthetic Motor Oil (XLFQT)
All TEMPS......5W-30 [1]
Below -20F......0W-30
Manual Transmission,NV4500......GL-4 [2]
Synthetic Manual Transmission and Transaxle Gear Lube (75W-90) API GL-4 (MTGQT)
Manual Transmission,ZF S6-650......SLF [3]
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Automatic Transmission,1000......AF6
Low Viscosity Synthetic ATF (ATLQT)
Automatic Transmission,4L80-E......AF6
Standard Differential, Front......GL-5
ALL TEMPS......75W-90 [4]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
Standard Differential, Rear......GL-5
Transfer Case,NVG 261-NP2......GLS [5]
Synthetic Universal Automatic Transmission Fluid (ATFQT)
Transfer Case,NVG 246-NP8......SLF [6]
No AMSOIL Product Recommendation
Transfer Case,NVG 149-NP3......GLS [6]
Transfer Case,NVG 263-NP1......GLS [6]
Fluids
Power Steering Fluid......PS
Power Steering Fluid (PSFCN)
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Clutch Fluid......HB
[1] SAE 5W-30 is preferred.
[2] Synthetic gear oil, GM part no. 12346190 or equivalent.
[3] GM part no. 12378515 or equivalent
[4] Synthetic lubricant, GM part no. 12378261,
or equivalent product formulated to meet
GM specification 9986115.
[5] GM recommends Part No. 88861800 (Canada 88861801)
or equivalent for manual transmission, transfer
case applications.
[6] GM part no. 12378508 (U.S.), 10953626 (CAN)
FILTERS:
Oil Filter Absolute Efficiency Oil Filter (EAO32)
Oil Filter WIX 51042 Oil Filter
Air Filter Absolute Efficiency Air Filter (EAA123) [1]
Air Filter Absolute Efficiency Air Filter (EAA123) [2]
Air Filter INJEN-AMSOIL Air Intake System (PF7050P)
Air Filter WIX 42488 Air Filter [1]
Air Filter WIX 42487 Air Filter [2]
Transmission Filter WIX 58904 Trans Filter [3]
Transmission Filter WIX 58847 Auto Tran Filter [4]
Transmission Filter WIX 58608 Auto Tran Filter [5]
[1] Heavy Duty Version
[2] Light Duty Version
[3] 4L60E - Shallow Pan
[4] 4L60E - Deep Pan
[5] 4L80E - Pan Gasket Reusable - Not Included
NGK PLUGS AND WIRESETS:
GPSERIES PLUG TR5GP
IXIRIDIUM PLUG TR5IX NGK7397
PREMIUMIRIDIUM PLUG ITR5F13 ^
PREMIUMPLATINUM PLUG PTR5D-10 *
VPOWER PLUG TR5 NGK2238
WIRESET WIRESET RC-GMX102 NGK51430 [1]
[1] "Use w/Coils Stamped 19005218 (9.2"" Leads)"
WIPER BLADES:
Blade Class Driver Passenger
ExactFit T221 T221
NeoForm T16220 T16220
Winter T37225 T37225
CHASSIS LUBRICATION:
2WD
6 Fittings, 0 Plugs..........LB
Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
Synthetic Heavy-Duty Grease NLGI #2 GC/LB (GHDCR)
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCTB)
4WD
11 Fittings, 0 Plugs..........LB
CAPACITIES:
Engine, with filter..........6.1 quarts [1]
Cooling System, With AT Electric Fan Initial Fill..........16.7 quarts
AMSOIL Antifreeze and Engine Coolant
Cooling System, With AT Engine Fan Initial Fill..........16.2 quarts
Cooling System, With MT Engine Fan Initial Fill..........16.7 quarts
Automatic Transmission, 1000 Initial Fill..........7.4 quarts [2]
Automatic Transmission, 4L80-E Initial Fill..........7.8 quarts
Automatic Transmission, Total Fill
4 speed 4L80-E..........13.6 quarts
6 speed 1000..........12.7 quarts
Manual Transmission, NV4500 (TOPC)..........8.1 pints
Manual Transmission, ZF S6-650..........12.7 pints
Differential, With 8.25 RingGear Front..........3 pints
Differential, With 9.25 RingGear Front..........3.6 pints
Differential, With 10.50 RingGear Rear..........5.5 pints
Differential, With 11.50 RingGear Rear..........6.4 pints
Differential, With 8.6 RingGear Rear..........4.3 pints
Differential, With 9.50 RingGear Rear..........5.5 pints
Differential, With 9.75 RingGear Rear..........6 pints
Transfer Case, NVG 149-NP3..........4.5 pints
Transfer Case, NVG 246-NP8..........4.1 pints
Transfer Case, NVG 261-NP2..........4.1 pints
Transfer Case, NVG 263-NP1..........4.1 pints
[1] After refill check oil level.
[2] DO NOT drain the fluid if only the transmission spin-on oil
filter is being replaced.
TORQUES:
Oil Drain Plug.....18 ft/lbs
Manual Transmission NV4500
Fill Plug 27 ft/lbs
Drain Plug 27 ft/lbs
Manual Transmission ZF S6-650
Fill Plug 26 ft/lbs
Drain Plug 26 ft/lbs
Transfer Case NVG263-NP1
Fill Plug 15 ft/lbs
Drain Plug 15 ft/lbs
Transfer Case NVG261-NP2
Fill Plug 15 ft/lbs
Transfer Case NVG246-NP8
Fill Plug 15 ft/lbs
Transfer Case NVG149-NP3
Fill Plug 15 ft/lbs
I have a 07 1500 Silverado with the 6.0 and I use CG 0w-30 year round. Runs great, oil pressure builds fast at start up and no ticking at all.
I think 99% of the time in Texas 0w,5w, and 10w-30 will all work well. Unless you get a severe cold snap. The Amsoil info I posted says 5w-30 preferred. But all three would be fine.
Originally Posted By: FL_Rob
Oilboy, that was a great gift of knowledge and formatting on the specs ,thanks for the time you put into it.
I just copied and pasted, no problem......
Bump.
I have same year 2006 but it's 1500 HD, I know it's identical to 2500 but 2500 HD is like 3500, so what are the differences?
Thanks for posting the specs above.
I've had good luck with all oil but mainly feed it M1 05W-30 with 7500 change intervals. I get about 12.5MPG and up to 14 if it's all highway about 60.
