I bought this used 2005 F-150 4.6L and Jiffy Lube changed the coolant to what I think is conventional green. Anyway, did a drain on the radiator today and only got about 6 quarts out of a 20 quart system. Normally this would satisfy me, but I really want to get all of the old stuff out. There is what appears to be a block drain right below one of the freeze plugs. Is it safe to remove this? If so, will this completely drain the cooling system? Is there anything I need to know when I reinstall it to ensure it doesn't leak? Teflon tape or replacing the plug all together?
