All,
Just changed oil at 10k and got the results back. All looks good to me except fuel in oil. Here's the results at 5k & 10k
Mi. on unit: 65,556
Mi. on oil: 4,908/10,011
Oil type: Rotella 5W40 (CJ4, not T6)
5k miles/ 10k miles
Cu: 2/4
Fe: 5/7
Cr: 0/0
Al: 0/1
Pb: 2/3
Sn: 0/0
Si: 4/4
Na: 1/2
K: 1/2
Mo: 50/49
Ni: 0/0
Ca: 1009/985
Mg: 1063/1013
Zn: 1259/1013
P: 1078/1012
soot: 0/0
oxi: 18/18
nit: 7/7
sul: 19/19
H20: N/N
glycol: N/N
fuel: N/Y
% fuel: NA/6.18
V100: 13.0/12.0
I found out recently that they don't report % fuel unless it's "high" or if you ask them to. The fuel might be from a bad injector, but I'm guessing it's just from running all winter with very light loads. I try to drive for good fuel economy, so the loads are always low.
Q) Since I didn't get % fuel reported at 5k, can you infer anything from the V100 to tell me if I had fuel in oil then? It would make me feel better if I did - less likely to be the injector if it's making oil at this slow of a rate.
FWIW, I recently got some fantastic fuel economy on a 100 mile trip (>29 mpg ~ 55 mph), and I wonder now if having a ligher oil could have played a role.
Trying to decide when to pull the next sample. Another at 5k, or sooner? Oil in it now is more of the same (last of my stash) Filters are M1.
Mi. on unit: 65,556
5k miles/ 10k miles
Cu: 2/4
Fe: 5/7
Cr: 0/0
Al: 0/1
Pb: 2/3
Sn: 0/0
Si: 4/4
Na: 1/2
K: 1/2
Mo: 50/49
Ni: 0/0
Ca: 1009/985
Mg: 1063/1013
Zn: 1259/1013
P: 1078/1012
soot: 0/0
oxi: 18/18
nit: 7/7
sul: 19/19
H20: N/N
glycol: N/N
fuel: N/Y
% fuel: NA/6.18
V100: 13.0/12.0
