Hey guys. This is my first post, and I thought I'd post a writeup covering the B-12 flush I did this past weekend on my car. Mods, if this is not the appropriate section, please move it.
Background:
The car is a 1997 Nissan pickup 2.4L 4cyl with approx 125K miles. It was bought used by my Dad at approx. 30K, and he drove it with and OCI of 5K miles using Castrol Syntec 10W30 and Fram filters. I started driving and maintaining the truck at 75K miles and also used Castrol Syntec and Fram filters, but I switched it to 5W30 instead of 10W30.
The truck has a KA24E engine, which some of you may know is afflicted with a timing chain rattle. This rattle is caused by a couple of reasons: 1. the chain tensioner or associated parts are broken, allowing the chain to rattle or 2. the tensioner is not actuating due to low oil pressure. I suspect in my own case that oil pressure is the problem since it only rattles when the engine is cold. Once it warms, the rattle goes away.
To rectify this, I decided to try a B-12 Chemtool flush along with a higher grade oil and filter. The oil I selected was Pennzoil Ultra 5W30 and a ST3682 Supertech filter. For the flush, I used a 15W40 dino oil combined with the B-12 and another ST filter.
I first drained out the old oil which had approx. 3500 miles on it. I grabbed a sample as it was draining. Since it was so dark after such a short OCI, I decided to replace the PCV valve as well.
Next, I replaced the Fram with the ST and fiiled the engine with the 15W40 and the Chemtool. I let the engine idle at 1500 RPM for 30 min (as suggested by member JohnBrowning) and then immediately drained the flush oil. I also grabbed a sample of this.
I then installed the other ST filter and filled up the engine with the PU. As part of this, I cut open the filters with a hacksaw.
Something I noticed about the flush oil: it smelled very strongly of Chemtool and it thinned the oil quite a bit. Also, there was a lot more “seditment” in the bottom of the flush oil than I expected. It was also a lot darker than I thought it would be.
In any case, I’m not sure how well this actually cleaned my engine. The rattle has gone away after startup, but that may only be due to new oil and filter. I tired grabbing some before and after pics through my fill hole, but they look almost the same to me.
My plan going forward is to monitor the oil closely to make sure that there’s no residual Chemtool breaking down the oil and to continue with the higher grade oil/filter to see if things improve.
In any case, I want to thank all the members here for making this site a great place to learn about oil. I have pics that I will post up later today.
Background:
