Here is the deal.
I have used magnetic oil plugs in my cars for a couple of years.
Usually only small amounts of gray fuzz on the plug.
I just changed engine oil in my 2003 Corolla with 63000 miles.
This time way more of the magnetic gray debris. Several times more than usual.
Comparable to that in long drain in diff. The texture is typical and similar to graffite.
Very fine particles (10 um estimate based on microscope image). Clearly iron.
5000 miles, 6 months interval, 70% city driving, 30% highway. 10W30 YBP oil. Purolator classic filter.
I opened oil filter with no surprises, small amounts of small carbon particles in the bottom of the filter.
The only things that were different this time:
PYB oil (previously QS peak), slightly more hwy driving (it's usually a city car), 5000 miles vs 4000 miles typical, Chevron 100% gas in the last several tanks (usually BP with 10% ethanol),
daughter learning to drive with permit (she drives gently though), oil was between full and empty rather than full.
No problems with the car or engine. No oil consumption. Now, this may be a pseudo problem,
considering that most people don't use magnetic plugs.
Any ideas? Could it be slightly lower oil level? Why? Hotter oil?
