Originally Posted By: KrisZ
While I agree that ATF is not designed to be in the engine, the reasoning behind your conclusion is not exactly correct.
Engineers don't write manuals, technical writer do. They may or may not consult the engineer, but largely they use technical documents to write the manuals. Then you have marketing, legal and warranty guys influencing the final direction of the manual.
My Mazda's owner's manual, for example, never mentions ATF change or flush, never mind the filter. All it states is to check the level annually and add fluid as needed. So, according to the manual, I should never worry about ATF changes, but we all know that AT life is highly reduced when ATF changes are neglected, and I don't think that anybody on this board would argue with me, if I decided to go against the manual and change the ATF.
If engineers were writing the manuals, we would have tons of maintenance items, we probably never heard of, and not a lot of people would actually understand them
Point taken. But your reasoning is not an apple to apple comparison. You state your owners manual doesn't call for ATF changes, but you choose to change your ATF. Zero harm can come of that. You are replacing a product (ATF) with the same product (ATF). The question at hand is not what to put into the transmission (we agree that it should be ATF), but weather or not the fluid needs changing. Oil and ATF are to completely different products. One is designed for an engine, one for a transmission. If it is ok to substitute ATF for oil, wouldn't one then be able to run oil through their transmission? For me, I'll trust the egg heads at Ford and Yamaha to tell me what fluids work best in my engine.
