I have a 1997 Ford F-250 4x4 with a 4.6L Engine. It developed a serious misfire with a Flashing Check Engine Light. I brought it to a garage and their “computer” SAID I HAD A SERIOUS Misfire on Cyl 4 and an “odd reading” on cyl 8. They went on to say getting an odd reading on 8 wasn’t unusual as it will try to pick up the slack from #4 misfiring. So, they replaced the plugs in #4 and #8 and started it up. The CEL went right out and it ran smooth. I drove it about 15 miles and it was perfect.
The next day I started it up and it was misfiring again. I spoke in a forum with a Ford Tech. I told him someone said I may have bad compression in #4. The tech said highly unlikely as putting a spark plug in wouldn’t have made it run well for a day. If the compression was bad, it would stay bad and plug wouldn’t do anything.
I am handicapped and can’t afford to keep running to the garage. So, what do you all think my next steps should be?
Replace my Plug Wires? Change the rest of the plugs? Coil Packs?
Standing in front of the truck looking at the engine, I have 2 coil packs…. One on the left side and oone on the right side. Which coil packs control which plugs?
It is more likely to be a bad injector?
Any help would be greatly appreciated.
Bob
Bob
