Originally Posted By: deeter16317
In the automotive application, how would your rate #274 to others? I just bought a case of it (a little late to ask I guess), trying to get some opinions.
274 is a great grease it's a versatile, multipurpose Aluminum Complex base, high resistance to wash out, aimed for cooler weather operation it's a syn blend good for temps -20 to 350 NLGI #2,it's a perfect grease for that plication.
i use #238(basically the same grease) it's more for summer time temps little thicker i use it for ALL my needs, chassis lube, heavy equipment pin and bush use,5th wheels etc,etc.
you made a great choice!!!
