Ustria?
by Pontual
02/06/16 11:48 AM
Georgia bans 71 oils from 29 brands
by Tom NJ
02/06/16 11:27 AM
Trying to send a Blackstone sample
by 15SilvyEcotec
02/06/16 11:10 AM
2005 Trailblazer getting a new engine
by The_Eric
02/06/16 11:02 AM
AAP: 5 qt Castrol Edge, Boss filter, $30 PP $33
by DoubleWasp
02/06/16 10:48 AM
Make own external backup?
by doitmyself
02/06/16 10:33 AM
What should I use for my next oic?
by dan_erickson
02/06/16 10:25 AM
Motul Sport Ester 5w40 vs Gulf Competition 5w40
by Brit33
02/06/16 10:12 AM
M1 0W-20 EP / 15,745 mi oci / 2004 Honda Accord V6
by vinu_neuro
02/06/16 09:58 AM
Recommend me a small 12v battery.
by dlundblad
02/06/16 09:22 AM
Painful To Find M1 5W30 ESP
by Virtus_Probi
02/06/16 08:37 AM
Conventional oil in a 3.6 Penastar ok?
by oilchangeguy
02/06/16 08:27 AM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
85 registered (A310, 77GrandPrix, Bandito440, bbhero, Abakev, Ball9320, 10 invisible), 1900 Guests and 205 Spiders online.
56834 Members
66 Forums
244311 Topics
Page 2 of 2 < 1 2
#1826007 - 03/21/10 05:26 PM Re: Oil for Subaru Forester 2.5X ? [Re: Nick R]
ProfPS Offline
Loc: CT, YL of USSA aka Oceania
Are there any oil requirements or specifications listed in the Forester owner's manual? Just curious.
Participating member of the BITOG Petroleum Reserve.
Thank you Commodity Futures Modernization Act of 2000.
O438A6R53A25C
#1826021 - 03/21/10 05:35 PM Re: Oil for Subaru Forester 2.5X ? [Re: ProfPS]
Johnny Offline
Loc: Retired | Wausau, WI
SAE 5W-30 and the ILSAC starburst label. I believe that's it.
#1826023 - 03/21/10 05:35 PM Re: Oil for Subaru Forester 2.5X ? [Re: bluesubie]
SilverGGA Offline
Loc: San Jose, CA
Originally Posted By: bluesubie
I've got three Subaru's running OEM Honeywell's and I'm just waiting for one to explode. grin
-Dennis
Aye, a lot of people are too smart for their own good. I will stay dumb and use the OEM unit.
04 Subaru WRX M1 HM 10w30 Extra S OEM Filter 109k
11 Honda Pilot LX PU 5w20 OEM Filter 52k
05 Mazda 6i 126k
97 Acura Integra LS 147k
95 VW Passat GLX VR6
#1826028 - 03/21/10 05:41 PM Re: Oil for Subaru Forester 2.5X ? [Re: ProfPS]
Chainsaw Offline
Loc: WI
Yes, The manual indicates one should use 5w30. The dealer says any kind would suffice. I did not talk with the service department yet and will do so this week. I might buy a case of the oil filters at the dealer and find out what oil they use (probably bulk) and let them change it the first time or two as they offer free tire rotation every 6000 miles. The dealer is about 1 1/4 hours away though so I'll change it every other time. Looks like the oil is easier to change than my Colorado pick-up is though.
#1826030 - 03/21/10 05:42 PM Re: Oil for Subaru Forester 2.5X ? [Re: ProfPS]
bodeh6 Offline
Loc: Metro Detroit, MI
On my 2006 Subaru Legacy 2.5i Naturally Aspirated the OEM Subaru filter is recommended since it is the only one with the proper Bypass Valve pressure. I used to get Valvoline 5W-30 bulk done at the dealer. I now bring in my own oil. I brought in QS Ultimate Durability 5W-30 in January. It seems to like it. Better in the cold then the bulk dino it used to get. Will change it again in a few months with the same.
Here is what the manual recommends
Should be the same for the Forester.
06' Subaru Legacy 2.5i 88K+ Miles
M1 HM 5W-30/OEM Filter
#1826031 - 03/21/10 05:43 PM Re: Oil for Subaru Forester 2.5X ? [Re: ProfPS]
tenderloin Offline
Loc: Huntington Beach, CA
I would hazard a guess that there are more Subies running aftermarket filters than Subie ones....with no oil filter related problems.
Bill from Utah seems to be the Subie oil and filter expert. Hopefully he will chime in.
My sons '07 2.5i has over 70,000 mile, most with aftermarket oil filters. I have used most name brand synthetics as well as Trop Arctic blend. Dealer uses Quaker State 5W-30 bulk which I have use a few times as well. Dino OCI's 5,000. Synthetic 7,500 give or take a few miles/
BTW the Subie runs and sounds better than new (have Pennzoil Ultra 5W-30 with Purolator PureOne Oil Filter PL14610 in it now)
#1826041 - 03/21/10 05:55 PM Re: Oil for Subaru Forester 2.5X ? [Re: Chainsaw]
WagonBoss Offline
Loc: Northern Virginia
Any 5w-30 conventional SM rated oil with a factory filter changed on a 3k OCI will be more than satisfactory for the life of the vehicle. Since it is a consumable item buy the cheapest SM rated oil.
That said, I use Valvoline Maxlife 10W-30 on a 6-7.5k OCI. I also court doom with a Purolator PL14460 filter (the only aftermarket filter with the correct by-pass rating) instead of the OEM because I don't like Honeywell. Works for me,YMMV.
2009 Outback 2.5i
2008 Impreza 2.5i
L14460/Formula Shell 5w-30
2004 Corolla
L14476/Formula Shell 5w-30
2012 Chrysler 300
Wix 57526/QSUD 5w-30
#1826149 - 03/21/10 07:33 PM Re: Oil for Subaru Forester 2.5X ? [Re: WagonBoss]
sicko Offline
Loc: Virginia
The non-turbo Subaru engines are easy on oil. If Mobil 5000 is what you've got then that's what you should use, no reason to buy oil specifically for it. M5k is a quality oil that will serve you well.
As for the oil filter, I use Purolator PureOne oil filters on my Subaru. My previous Subaru went 9+ years on mostly third party oil filters and never had a lubricant related problem, or any issue that could have been caused by the oil or lack of filtration. The PureOne filters have the highest bypass setting (14-18 PSI) of any third party filter I've found, which brings them the closest to the OEM 21-23 PSI. I have no fears using the PureOne oil filter, but if you really want to get the 21-23 PSI bypass value, then you should go OEM.
Subarus are great vehicles, with great engines, and the non-turbo Subarus are easy on oil. Use whatever you have on hand and you should be fine.
BTW, owner's manual states 4.2 quarts, but I believe Subaru has since mentioned that that is without a filter change and that it's about 4.5 quarts with an oil change. Either way I have to purchase 5 quarts of oil when I do a change, I put in 4 quarts and then add from the fifth quart until its full.
Is this your first Subaru? Have you had a chance to take it out in the snow/ice yet? That's were Subarus really shine, the AWD system is excellent (but don't let yourself get over confident to the point you start doing stupid things). I gotta say though that OEM tires on my '09 Forester leave a lot to be desired. Even with the VDC it seems like the back wants to swing out when driving in snow. My old Forester didn't do that, so I can't wait till these are worn down enough to need replacing
#1826234 - 03/21/10 08:39 PM Re: Oil for Subaru Forester 2.5X ? [Re: sicko]
Chainsaw Offline
Loc: WI
First Subaru, and my wife is the driver 99% of time. I drive Chevy pick-ups. She previously had an S10 Blazer and likes the way the Subaru handles in the snow and on the road in slippery conditions. She is up to 25mpg and likes the vehicle just fine. I'll keep in mind the 4.5 qts of oil when I change.
#1826598 - 03/22/10 08:08 AM Re: Oil for Subaru Forester 2.5X ? [Re: Chainsaw]
ARCOgraphite Offline
Loc: N.H, U.S.A.
The new Forester is not good in the snow compared to any of the 6 other subarus I've owned. May be tires but - its a tall empty box and I dont like the new rear suspension or the terrible VDC ETC. Thankfully there is an OFF switch. I wish there was an OFF switch for the hill holder too - that almost got me in the ditch too.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#1826655 - 03/22/10 08:51 AM Re: Oil for Subaru Forester 2.5X ? [Re: ARCOgraphite]
Bill in Utah Offline
Loc: UT
I've got a 2007 Subaru with the same engine. Cut open many a filter and posted the results here. Also a few UOAs.
I'd run any 5w-30 conventional with any CORRECT sized filter. (the longer filters get WAY too CLOSE to the header/cats on the engine)
Halvoline DS 5w-30 was a excellent fill as is really anything else I've tried.
Mine is the BEST thing I've EVER driven on ice and snow. (and I've driven for decades in the ice and snow) The Goodyear triple treads are AMAZING in every aspect. (the factory tires were good, but one was damaged in the accident so we had to replace ALL of them)
Excellent power train (a little quirky) and SAFE vehicle (ours was hit by a semi @ 8,000 miles and once fixed is like new 3 years later) A well thought out vehicle.
I was thinking about selling our Outback and picking up a Forester. If the current Forester was avail when we bought out Outback we would have ended up with one. For the $$ I feel its the best rig out there for most peoples use in 4 seasons.
We could not really justify spending another $6-8k for a newer vehicle when ours has only 36k miles and is like new.
We are going on a 6,000+ mile trip this summer and will be taking the Outback. Reports will follow.
Here are a few threads on my Subaru;
Rear diff fluids
Some things done to the new car
Subaru factory oil filter photos
Supertech filter opened
Here are UOAs of the factory fill, DS and PP.
PureONE filter cut open
Scroll down for PureONE filter off the Subaru
Thread on ATF for the Subaru
Goodyear triple tread ire thread
Another Supertech filter opened
That will give you all the threads that I've started on Subaru. grin
Take care, bill
#1830347 - 03/24/10 11:24 PM Re: Oil for Subaru Forester 2.5X ? [Re: ARCOgraphite]
Langanobob Offline
Loc: Reno, Nevada
[/quote] I own one too(09), and have tried many oils. Rotella T 10w-30 works very well as does 3 quarts 5w-30 Mobil 5000 and 1 qt 10w-40 Mobil 5000. The 10w-30 for some odd reason doesnt work well. A Wix 51356 (not 65) is prob the larget quality filter that will fit. I would absolutely get the watery 20w break in oil out ASAP as we lost a rod bearing to this "water" Subarus like thicker oil. Good luck. [/quote]
The original oil caused a rod bearing to fail in a new vehicle??? Seems to me there has to be more to this story. Would you mind providing more of an explanation? Or maybe a link to a thread where you already explained it? Sorry if I sound like a disbeliever, but I guess I am.
Thanks,
Bob
#1830529 - 03/25/10 07:51 AM Re: Oil for Subaru Forester 2.5X ? [Re: Langanobob]
webfors Offline
Loc: Great White North.. eh
Agree with Bill. My Forester is the simply amazing in the snow.
I'm using PP5w30, will be going to QS 5w30 conventional for the summer/fall, then use one of my remaining PP jugs for winter, and do the same cycle for another year before I need to buy more oil.
For the filter, I like the black tokyo roki filters, but you can't get them anymore. The OEM filter is a decent filter with the right specs. My next choice would be a Purolator Classic or PureOne. I'll be using one of them after my stash of roki's are gone.
15 Civic, AFE 0w20, FU OF
13 Dodge GC, VWB 5w20, Purolator OF
13 SFV650, T6 5w40, OEM OF
07 VS800, OEM 10w40, K&N OF
Small engines; RT5 10w30
Page 2 of 2 < 1 2
