Any thoughts on how this looks?
Miles on truck.........160,000
Miles on oil............3,653
Oil......................Delo 15W-40 400 LE
Parameter.......Universal Average 3,653miles.... UOA Results
Aluminum.......................3.....................5
Chromium.......................2.....................2
Iron..............................23....................33
Copper...........................4.....................6
Lead.............................2.....................2
Tin...............................1.....................0
Molybdenum....................27....................74
Nickel............................0.....................0
Manganese......................0.....................1
Silver............................0.....................1
Titanium........................0.....................0
Potassium.......................4.....................2
Boron...........................80....................389
Silicon...........................7.....................6
Sodium..........................4.....................3
Calcuim.......................2733..................1975
Magnesium....................244...................447
Phosphorous..................1079...................1123
Zinc...........................1270..................1465
Barium..........................1.......................0
SUS vis at 210 F............69 to 78..................75.1
cSt at 100 C................12.7-15.3.................14.29
Flashpoint....................>405.....................420
Fuel.......................... Antifreeze......................0%......................0
Water........................ Insolubles.....................
Report read:
Showing some excess wear at steel parts at the time sample was taken. Universal averages show normal wear for the Cummins 6 BT 5.9L after 6,850 miles of oil use. This oil was in use just 3,653 miles and iron read at 33ppm. That shows excess wear from either cylinders, rotating shafts, parts in the valve train or a combination of all three. Other wear metal were okay. No containments were found. Try ~4000 miles on the new fill then check back to monitor iron wear.
Thanks,
David
Report read:
Thanks,
David
