Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
Briggs 'Quantum 6.0' Flathead top no load 2600RPM
by Colt45ws
07/28/16 09:15 PM
EPA efficiency testing may not work, at all
by wemay
07/28/16 09:11 PM
Mobil 1 0w40 for 2013 4.8 V8
by CapitalTruck
07/28/16 09:04 PM
2013 Passat service
by powersmo
07/28/16 08:24 PM
A/C troubleshoot
by Leo99
07/28/16 07:50 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
24 registered (chance, earlyre, Drosselmier, CATERHAM, Ducked, 3 invisible), 909 Guests and 9 Spiders online.
58632 Members
66 Forums
252385 Topics
Page 1 of 2 1 2 >
#1825932 - 03/21/10 04:35 PM Oil for Subaru Forester 2.5X ?
Chainsaw Offline
Loc: WI
We have 2400 miles on a recently purchased 2010 Subaru Forester 2.5X with the EJ253 4 cylinder SOHC engine NON turbo. Will change at 3000 miles.
What would be a good oil for this engine? I have Mobil 5000 on hand, but would consider others.
Owners Manual indicates the engine oil capacity is 4.2 quarts. Noticed that the oil filter is somewhat small. Any other "larger" filters that would work?
Thanks for any info you would have.
#1825934 - 03/21/10 04:37 PM Re: Oil for Subaru Forester 2.5X ? [Re: Chainsaw]
Nick R Offline
Loc: Albany, NY
Every 3K? Go with Quaker State 5W-30, PYB 5W-30, or Valvoline WB 5W-30. You could run any one of those for 5K or so with no trouble.
2013 Ford Focus SE 2.0L/73,000miles/Motorcraft Blend 5W-20/FL-400S
#1825944 - 03/21/10 04:44 PM Re: Oil for Subaru Forester 2.5X ? [Re: Nick R]
Steve S Offline
Loc: East of IGO
Mobil is a great oil as is most any of todays proper rated oils.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1825946 - 03/21/10 04:47 PM Re: Oil for Subaru Forester 2.5X ? [Re: Chainsaw]
Chainsaw Offline
Loc: WI
I was reading that no aftermarket oil filter meets Subaru specs. Any truth to that or should I purchase Subaru oil filters?
#1825948 - 03/21/10 04:47 PM Re: Oil for Subaru Forester 2.5X ? [Re: Steve S]
ottotheclown Offline
Loc: new york
I would suggest Mobil 5,000 then Havoline, then Formula Shell all great for 3,000 mile changes. But why 3,000 mile changes??? severe service? Lots of short runs etc. ??
ottotheclown
#1825950 - 03/21/10 04:49 PM Re: Oil for Subaru Forester 2.5X ? [Re: Nick R]
2oldtommy Offline
Loc: Ohio
For a larger filter, the Purolator Pure one PL14610 (or equivalent) is longer than your stock filter. The bypass valve opens at the same 8-10 lbs. and the gasket diameter is identical. It also has an ADBV. FWIW--- Oldtommy
#1825955 - 03/21/10 04:52 PM Re: Oil for Subaru Forester 2.5X ? [Re: 2oldtommy]
Johnny Offline
Loc: Retired | Wausau, WI
I believe he said it now has 2,400 miles on it and he will be changing it at 3,000 miles. Unless Subaru has changed their recommendations since I owned one, I believe their severe service schedule is 3,750 miles on an oil change.
Any of the quality brand 5W-30 oils will serve you well.
I'm old school when it comes to filters and I would use the filter that is sold at the Subaru dealer (and I don't care who makes it), Subaru recommends it.
#1825957 - 03/21/10 04:53 PM Re: Oil for Subaru Forester 2.5X ? [Re: Nick R]
TheMAN Offline
Loc: Dallas, TX
the Subaru 15208AA020 filter was basically the same as the Mazda B6Y1-14-302A oil filter... both being made by Tokyo Roki... the filter is no longer available in the US and now is a 15208AA12A made by Honeywell... the quality difference is significant but I don't know if anyone has cut one up yet to see what it's like... the dealer cost difference for these were also significant, so that was the true motivating factor for going from Tokyo Roki to Honeywell for Subaru of America... the dealer local here got smart and ended up selling the last of the Tokyo Rokis to some enthusiasts for 2x the original MSRP once they were no longer available/hard to find LOL
if you want something larger, the Mazda JEY0-14-302 -9A (for V6s) filter will fit perfectly just like the B6Y1 filter... you don't want to use the Subaru 15208AA031 (6 cyl) filter because the threads are offset more, which causes the filter to barely thread onto the engine (this is on top of the fact that the relief valve setting is different, though I've seen several people use this filter on their boxer 4 subarus and swear by it)... both of the mazda filters mentioned are made by Mahle (sometimes you may get old stock by Tokyo Roki, and if the stars aligned, Tennex also... either 3 are awesome filters), the B6Y1 being the same size as your stock one, and the JEY0 being a taller one by half an inch
#1825958 - 03/21/10 04:56 PM Re: Oil for Subaru Forester 2.5X ? [Re: Chainsaw]
ARCOgraphite Offline
Loc: N.H, U.S.A.
I own one too(09), and have tried many oils. Rotella T 10w-30 works very well as does 3 quarts 5w-30 Mobil 5000 and 1 qt 10w-40 Mobil 5000. The 10w-30 for some odd reason doesnt work well. A Wix 51356 (not 65) is prob the larget quality filter that will fit. I would absolutely get the watery 20w break in oil out ASAP as we lost a rod bearing to this "water" Subarus like thicker oil. Good luck.
2014 Nissan Rogue S CVT, OC#4 19671mi-Castrol EDGE EP 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#1825962 - 03/21/10 04:59 PM Re: Oil for Subaru Forester 2.5X ? [Re: 2oldtommy]
Captain_Klink Offline
Loc: Afghanistan
I use the Bosch 3323 or the corresponding Gold Napa, or PureOne.
This filter is longer than stock, and it works better because the filter medium surface area is greater, which mean the filter will last longer. i change every 3000 miles, and that is the recommended by Subaru Canada. in USA severe duty is 3750, but you are always better to err on the shorter side - also, i change the filter every other time - meaning every 6000 miles, which is still less than the "regular" USA interval of 7500 miles.
As for choice of oil it doesn't matter much, any oil is good as long as it is 5w30, and i use 50% synthetic with 50% conventional. i mix it myself.
Because the filter is bigger, you could even change it only every third time - every 9000 miles, but people here complain about "why did you take a bath and then put back on your dirty underwear?"
assda
Edited by Captain_Klink (03/21/10 05:02 PM)
#1825964 - 03/21/10 05:00 PM Re: Oil for Subaru Forester 2.5X ? [Re: 2oldtommy]
Loc: N.H, U.S.A.
Subaru spec is 21-23 PSI but more at TURBO apps not NA. I think the wix 51356 is a RX7 and early RX8 filter. I would look into getting a MAzda Mahle unit too.
#1825974 - 03/21/10 05:04 PM Re: Oil for Subaru Forester 2.5X ? [Re: ARCOgraphite]
Loc: N.H, U.S.A.
Engine is easy on oil as it has moly coated piston skirts and NO timing chain, NO hydraulic tappets. The short pistons and INSANELY short stroke/bore aspect ratio require an oil with a higher HTHS than 3.0 though. Forget Havoline DS 5w-30. Engine HATES this oil (I'm running it now - blecchh!)
#1825982 - 03/21/10 05:07 PM Re: Oil for Subaru Forester 2.5X ? [Re: ARCOgraphite]
TheMAN Offline
Loc: Dallas, TX
the local subaru dealer here uses valvoline durablend 5W30 bulk oil FWIW... of course I think the maxlife is better than the durablend wink2
I think subaru is one of the last holdouts on 30 weight oil instead of going to the 20 weight water like everyone else has
#1825985 - 03/21/10 05:09 PM Re: Oil for Subaru Forester 2.5X ? [Re: ARCOgraphite]
bluesubie Offline
Loc: NJ
With the exception of ARCO's experiences, grin, n/a Subaru's are easy on oil and you can run most anything. I would definitely stick with the OEM filter during the warranty period.
I've got three Subaru's running OEM Honeywell's and I'm just waiting for one to explode. grin
-Dennis
'04 Subaru Forester 2.5XT
Mobil 1 0W-40
#1825994 - 03/21/10 05:17 PM Re: Oil for Subaru Forester 2.5X ? [Re: TheMAN]
Nick R Offline
Loc: Albany, NY
I'm fairly sure GM still recommends 5W-30 in most of it's engines too.
Page 1 of 2 1 2 >
