In doing some research rather than winging it. i believe I have the answer to the name of the proprietary coating used in the Briggs Aluminum engines. I believe it is called stelite
Stellite® cobalt base alloys consist of complex carbides in an alloy matrix.They are resistant to wear, galling and corrosion and retain these properties at high temperatures. Their exceptional wear resistance is due mainly to the unique inherent characteristics of the hard carbide phase dispersed in a CoCr alloy matrix.Stellite® 6 is the most widely used of the wear resistant cobalt based alloy sand exhibits good all-round perfor-mance. It is regarded as the industry standard for general-purpose wear resistance applications, has excellent resistance to many forms of mechanical and chemical degradation over a wide temperature range, and retains a reasonable level of hardness up to 500°C(930°F). It also has good resistance to impact and cavitation erosion. Stellite® 6 is ideally suited to a variety of hard facing processes and can be turned with carbide tooling. Examples include valve seats and gates;pump shafts and bearings, erosion shields and rolling couples. It is often used self-mated lining of soft metals such as aluminum that require resistance to high heat, fiction and wear.
I cant seem to find a direct link to briggs, they are very tight lipped regarding the lining of the cylinders in aluminum bore engines. I could have sworn it was a nikasil lining but i just kind find ANY information regarding what they use as a lining. what ever it may be, i have personally had extreme durability with the aluminum bores. An 40+ year old lawn mower with a three HP thats been handed on down the family chain and I now use it for mowing the sides of my 800ft driveway, banging many a rocks and stumps along the way. A Bolens ST1100 with 1400 hrs on the clock of an aluminum bore 11 hp, still runs as new and burns no oil between 15-20 hr change outs. I do use wally-world 5w-30 synthetic in it however. A late 60's Simplicity walk behind snow blower with an 8 hp briggs. what a tank that thing is. For instance, my Dad bought a husqvarna with a 11 hp that cost him 1200.00 and that 'ol simplicity will put it to shame. It also runs as new, starting in the second pull every time, winter, summer, fall...full choke and second pull it fires off, I would place a monitary bet on it even if it had been sitting all summer. it,too, burns now oil and is very strong. I also have a Toro Personal Pace lawnmower with a Quantum aluminum bore side valve that cost me 699.00 at the dealer with 12 v electric start and a small battery that i charge once per year. i have had it for three seasons and it runs as perfectly and quietly as one could hope for on a push mower. it is a 6.5 HP.
So I dont know if we will ever get to the bottom of it. However, the original poster need not be concerned as I personally believe they are perfectly reliable engines with a 45+ year track record. I also feel the side valve flathead's are far superior to the newer OHV engines. My 212-H Toro rider has a 12 I/C and is at the 1800 hr mark, the highest of any power toys I own. It smokes just a tad at start up and if you go from slow idle to full throttle you can see a very faint blue hue to the exhaust. I have not had to add any between changes yet but is does drop from full to the lower end between add and full on the stick at 25-30 hours. i also use the wally-world 5w-30 synthetic in that machine. Chassis has held up amazingly well...very tough for what wheelhorse designated as a lawn tractor! I wouldn't hesitate to do anything with it that i would do with my 72 Raider.
