A old friend of mine drains his oil hot,then fills the crankcase to proper level ,with diesel fuel and a quart of marvel mystry oil ,,runs for a short time,lets sit for a half hour,drains ,fills with a cheap 5w-30 runs for a 10 mile ride,drains and filter,then installs good oil and filter,he does ths every 3-4 oil changes,,,uses only Penz,10-30,,,,has over 280k on his old 2.4 toyota engine,,I helped him change out the valve cover gasket last week ,,,the engine was spotless inside the upper,,he also admits using Tuffoil additive every 50k,,,huh?? ,,,also noted what looks like hone marks on cam.........BL
