I am having problem with my Honda HRR216, which I have two of them with same symptom. The engine starts fine but when running at optimal speed, it would surge up and down. You can even see the spring mechanism (governor?) moving back and forth.
If you move the level *with the rabbit and turtle* all the way down to the rabbit, it would run normal, but no cutting power.
I search of the problem, it seems like these models have bad carbs and some replaced them said they ran fine after that. I took off the carb twice to clean, still same problem.
The third time, I opened the fuel bowl at the bottom and notice a pointed piece like a valve must have fell of somewhere. I beleive it fell off of the place inside the bowl where the fuel enters as there is this floater mechanism. Now it will only run in rabbit mode, any less it shuts down.
