adjusting the valves on an older Honda 4 banger is a totally different ballgame then on the newer v6's.... before you just took out a few valve cover bolts and you had access, now its not that easy, especially if the car has clearance issues under the hood with the rear head like an odessey
I agree with the spark plugs, they are so easy to change just run them until you get your money's worth out of them
and to the guy hating on the Honda 3.5 and tooting his horn over a 3.4 chevy motor........ come on man... I'm sure most people who have had experience seeing many cars go through their shop, would much rather depend on the 3.5 vs the 3.4
I can name more then a few things that are bad with 3.4's that I fix on a regular basis...... The honda's just keep on running along.. I think i've changed one coil on plug in a couple years.....
