Hi. Car had been operating with Blown head Gasket for a while.. last time it Overheated, i added a gallon of Water into the COOLANT (NOT oil) and when i came back two hours later.. the Oil looked like Milkshake.
Had car towed home, put in new Oil, tried to turn it over.. Went to Milkshake again.
I let the Crankcase drainovernight, the bolt is still off. but how does Oil get to look like Milkshake?
The new head and Gaskets are going on -tomorrow,- but i think once the Head and Gasket is changed, it will start and run (Water in Oil kills Combustion.
Has anyone ense had their Oil turn to Milkshake, and are there any pother Gaskets involved in the Job? I also have refrained from trying to clean the replacement Head, as i dont know How..
factory Fill will be a Blend, to make it 7.5W-30 w aurts 5W-30 and 2 quarts 10W-30) -- Why do people say to do a 500 mile OCI after doign the job, is that "heat Cycling" and the remainder of the water that WAS in there will go away?
