From what I understood, those who have replaced the PCM had no problems for a couple of years, then it would happen again. Also from what I read, the shift kit should help this because if you are changing the mechanics of the shift, making it shift a little bit harder without the help of the PCM, if the PCM were to slack up a bit, the stiffer springs might overcome that enough to not set it off. Now that I have learned about all this, before I put the shift kit in, I could pretty much determine when my car would max adapt. After driving for a while 1-2 would get real sloppy, then max adapt would kick in. So far with the kit in, 1-2 has been a healthy shift, even under part throttle, where you can actually feel it shift now.
With the MAF, how do you go about fixing that problem? Also, this max adapt doesn't occur very often on my car, I just want to try to prevent it from doing it as much as I can.
