Originally Posted By: wolfc70
How cold does it get in your part of NY? This is my routine in the morning, start the car, scrape windows, drive car. Idling for 3 min is not the worst, but unless it is below 0f, there really is no need to. When leaving school do this; start car, clean windows if needed, load favorite cds/tune radio/turn iPod on, take the long way out of the parking lot, then merge on to the freeway. Granted do not go chasing the redline or use WOT, but you can drive pretty much normally after 3-5 minutes of running.
Even when it gets really cold, like this past January when it was -22F one morning, I never let it idle for more than a few minutes. My car takes a long time to warm up idling, the temp gauge moves much quicker under normal driving conditions.
Its usually 20-30ºF, but dips down to 0-10º often. The difference between the car at 30º and 0º is extremely noticeable. At 30º it starts and runs generally fine, at 0º everything feels very slow. My car warms up reasonably quick at idle, 3 mins takes 30º coolant up to 130º.
