Originally Posted By: Oregoonian
I think the question is ... if your paying twice or even three times the cost of a good Syn or Blend...are you getting double or triple the protection...I doubt it! So thats enough evidence that your wasteing money on these high priced, so-called superior oils (Amzoil, RL etc.) and filters.
No, this is not the question. The correct question is to find an oil that can be carried out for extended oil change intervals. As mentioned, I'm doubtful similar results would be achieved with a dino or blend. As for a good syn ... which one? I'm only aware of a minor few that are true cat iv or v synthetics basestock versus highly processed group iii's. Also, the cost of true syns are comparable to RedLine. In any case, I understand your position but as I found good results with RedLine, I'll pay the extra cost and continue the placebo effect.
And Jeff, I'm not sure what you're asking? The TBN value of this oil is very good.
Doug
Doug
