Hi guys,
recently, I had a sweet smell once in a while in my car and I went to my mechanic and we say coolant under the car and it pointed out to be the water pump leaking when getting very hot + when load is applied.
They changed the water pump and while at it, I asked them to flush the entire system (radiator, heater..). They put fresh new coolant in it to the full cold line.
The car is a 2005 Cadillac CTS and I don't have a radiator cap, only a surge tank cap on the reservoir.
200 miles after the repairs, I had to add about 100 ml since I'm a perfectionist and just love when things are right at the line!
1000 miles after topping off, I had to had another 100 ml of coolant.
Could air trapped in the system cause coolant level to drop slowly? I'm going to change the reservoir cap as a preventive maintenance next week because I'm not sure if it could be a bad cap or not.
If air trapped in the system can cause my problem, is there a bleeder valve somewhere?
Thanks a lot.
Thanks a lot.
