Originally Posted By: NHHEMI
I have also had vehicles with a lot of valve train noise with more restrictive filters while under load and warmed up. My 05 4.0L Tacoma did this BIG TIME! That thing sounded like the VT had NO oil while driving @ 1700-2000+ RPM's. Swapping to a better flowing brand of filter reduced/eliminated the noise. It should be noted that this situation more than likely happens due to poor oil flow in the engine design.
Hummm ... what filter was on the Tacoma in that case?
I've used both the larger Toyota OEM and also long version PureONE on my 2005 Tacoma 4.0L V6, and it's quiet at any RPM. I don't baby the truck either ... she really scoots above 4000 RPM.
The OE filter did it, a Bosch filter did it, and a Hastings filter did it. Swapped over to a Mobil 1 filter and it almost went away. Same results with a K&N.
This problem was common to the 4.0L Tacomas at the time I had mine. Not everyone had it( heard it? )but lots of guys on the Toyota boards with it. Many many threads about it and what filters helped and what ones didn't.
Just one of the myriad of issues with the biggest piece of crud vehicle I have ever owned.
Hummm ... you are the only guy that I've heard of that has said anything about the oil filter making a difference on thier 4.0L V6 Tacoma (2005+ models). I hang out on a few Tacoma boards and never heard anything about this. I DID however, hear about the "pinging" sort of noise caused by the exhaust manifolds, and there was a TSB on them to replace them with a newer design manifold. Maybe this was the noise you were hearing. I can't believe the engine would be that sensitive to oil filters without have some kind of other mechanical issue going on.
My 2005 Tacoma has been great ... no problems with mine, guess I got lucky because I know some has issues and hence there are probably 15+ TSBs out there for them.
