Originally Posted By: heypete
Originally Posted By: kballowe
He's supposed to bring the car over this weekend so I can look at it. Is there some special magic involved in changing a canister oil filter on these new Camrys?
From what I've been able to find out, evidently the housings for the cartridge filters are quite sensitive to torque values. Be sure to use an accurate torque wrench.
I'm not sure if special tools are required. I don't think they are for my fiancee's 2010 RAV4, but I could be mistaken.
Also, the filters are likely available for a modest price from your Toyota dealer. The few aftermarket cartridge filters I saw didn't seem to be nearly as high-quality as the Toyota ones.
Personally, I like spin-on filters better as there's less chance of damaging the filter element, a wide variety of options from the aftermarket, and (if one does it right) no contact with used oil. Changing filters also renews various rubber parts, like the ADBV.
http://cgi.ebay.com/ebaymotors/GENUINE-T...=item3eee5db9ff
$46 shipped for a case of ten Genuine Toyota filters. Plus there's 8% Bing Cashback right now.
Cartridge filters are also cleaner to change. You can drain the oil from the housing before removing the element.
As long as you are careful, you probably won't need a torque wrench. Then again, I can't speak for anyone's mechanical skills (but my own), so a torque wrench is probably a good idea if you are unsure.
Yes, it's plastic.
Dealer also said that he should bring it in to them because it was very complicated. Something about making sure that the center stem doesn't come out or he would be buying another engine.
That warning wouldn't be a bad idea for some cartridge filters, especially the VW 2.0T ones. The thickness of the housing is about the same as a red party cup. When you remove the filter cap (which is always super tight for some reason), it feels like you're going to shear off the entire housing. And lots of people have-- and find they have to replace it at a cost of $85.
Yes, it's plastic.
