Occasionally when it rains I'll get some water dripping down through my furnace's flue. Not flowing or anything, but drips that come out at the top of the furnace where the vent is attached and run down the furnace and onto the platform it's sitting on. It seems like this only happens when it rains hard for several hours or more. I just end up putting some towels at the bottom to absorb the moisture and try to turn the thing up high enough that it runs regularly to evaporate all the water.
The furnace is 20 years old. Is this normal at all? I realize it's not "normal" for a new installation (or at least, better not be) but is it common on older ones? I haven't gotten on the roof to check the vent cover yet but it's on there, and I think if it were really bad I'd be seeing more water. Since it's coming down through the pipe I don't think it's a sealing issue around the vent.
I'm just trying to figure out how much I need to worry about this. The whole furnace is going to need some TLC but I'm trying to wait until late spring or summer to deal with it so I don't run the risk of ruining something and being without heat.
