Hey fellas, I am about to run an experiment on my car with larger injectors and ported intake system.
The plan is to get fuel injectors from a 3.2L engine and install them on my 3.0L.
The gain of fuel must be matched by some extra air which is where the bottle neck of the system will be ported, mostly around the throtle bodies of the engine...
The thing is the injectors that I am getting are 100K old... so I bet their spray pattern may be somewhat affected...
Is there a solvent or a chemical that will clean them on a home basis...
Cleaning service runs up around 15$/injector and I got 6 to clean include shipping etc... that will be 100$, and the injectors are around 45-50 to get to my house... so this will turn into an expensive night mare.
So can i use a over the counter solvent to clean them up before install... and which one will work the best?
Any info will be helpful.
THANKS.
THANKS.
