Originally Posted By: severach
Originally Posted By: NHHEMI
Seafoam... It is a 100% petroleum based product.
Isopropyl Alcohol is neither petroleum nor drinkable.
The amount recommended for engine oil is so small that the alcohol shouldn't be a problem.
Seafoam is not Isopropyl Alcohol. As I said Seafoam is a 100% petroleum based product. Also, when did anyone say anything about drinking it?
Quote:
Sea Foam Motor Treatment is blended oil, and WILL NOT run a gasoline, gas/oil mix or ethanol engine without introducing HYDROCARBONS (gasoline / ethanol) to the mixture at a minimum 50%
Quote:
Sea Foam Motor Treatment is a unique 100% pure petroleum oil product, developed to solve specific problems that are common to gasoline, gas/oil mixed fuels & diesel fuels used in all types and styles of 2 cycle, 4 cycle, diesel and Rotary (Wankel type) engines in common use in all automotive, truck, fleet, industrial, agricultural, specialty industries and small engine applications.
Quote:
SEA FOAM Motor Treatment is a 100% pure petroleum product that safely and effectively cleans internal fuel and oil system components, helping your gasoline or diesel engine run cleaner and more efficiently. SEA FOAM is an EPA-registered product, and will not harm engine components, seals, gaskets, catalytic converters or oxygen sensors.
