Originally Posted By: hate2work
Originally Posted By: Cujet
I've been saying this for years: Two stroke oil ratio's do affect engine life.
Duh. That is a given. Anyone that's been around two strokes for 20 minutes should know that.
High performance engines show less wear on 32 to 1 vs. 50 to 1.
Not true at all. Using the correct oil at 50:1 produces no more wear than a richer mixture.
While everybody hates a smokey, smelly 2 stroke, the facts speak for themselves. Engines last longer and perform better with more oil.
Again, not true. Engines last longer and perform better with the correct amount of lubrication, and that does not mean more oil is better.
Years ago, I worked as a junior mechanic for a group doing testing for Mercury Marine. Since, it was a long time ago, when 2 strokes were king, I won't say the data applies to all 2 stroke engines today. Not to mention a Shindawa 4 stroke.
However, I did do many of the teardowns for the engineers. I also did quite a bit of precision measurement and became quite familiar with Nikon microscopes. I did not have access to the final reports, but I can give my opinion on what I saw.
I stand by my "facts" with regard to high performance 2 strokes and oil ratio's. We measured output with differing ratio's. The reason for the test was a report by McCullough claiming oil ratio affects output.
What I remember from the test is that highly tuned race engines are hard on components and wear much more quickly than the average engine. Mainly due to port size. But also due to RPM's and the doubling of the output.
We measured output with a wide range of ratio's. We also disassembled engines to measure wear. The 16 to 1 engines made the most power, were substantially cleaner inside and had the least wear. Yes, I know, that goes against conventional wisdom, but we were in the business of winning races and selling engines. Which we were very successful at, I may add.
8 to 1 produced the most power but was difficult to use.
16 to 1 was nearly as powerful as 8 but ran properly.
32 to 1 is enough protection for all but the most radical engines.
50 to 1 produced slightly more wear in modified engines.
100 to 1 resulted in significant wear, scuffing and ultimately crankshaft overheating and failure in highly modified engines.
Once again, this was long ago, oils are better now and so on. But the facts remain,
100 to 1 is risky for a number of reasons. Engines with high specific output should avoid 100 to 1.
I don't know, but that Shindawa may have a need for significant lubrication.
EDIT: lean oil ratio's resulted in significant wear of the cylinder directly above the exhaust port.
