Originally Posted By: ThirdeYe
Originally Posted By: TWS
I have a 2001 Acura 3.5 RL, basically the same car as that, great car, the only problem I've had in the past five years is the main relay, the relay contacts develop resistance, create heat, and desolder themselves from the circuit board!
I'm an electronic technician, so I fixed the board myself, but the main relay only costs $50, so it's not too bad to replace the whole assembly....
Had the same problem with my Integra. It's pretty common for most Honda vehicles to have this happen over time. I was able to use one that was made for a Honda Civic on my car.
common issue on late 80's and 90's honda/acura. problem is that the car will not turn on after being turned off. usually occurs in hot weather. i think acura may have resolved this issue in the later integras, well i hope so atleast. Mine is has been good....Knock on wood
my 88 civic did this.....i was so stupid that i went to buy a new battery. doh...and kragens(douchebags) tested my battery and lied to me that i needed a new battery.
