Originally Posted By: Ben99GT
I've never heard of RL's race oils having higher ester content than their street oils, but I just sent Dave at RL an e-mail asking him about this. In fact, I've always understood that Redline uses the optimum amount of POE for the desired seal swell/polarity characteristics, cutting it with PAO (used as their additive carrier) to keep it in check.
If Dave replies that the race oil has a higher ester content, I will be surprised. All the more surprised considering their race oils and the street oils are roughly the same price.
I'd REALLY like to know this info as well!!
PLEASE post Dave's response.
IF that is the case, then it looks like I will be throwing in a quart or two of the Racing 30, or 40 weight at my next change.
I never got a reply, probably the first time I haven't gotten a reply from Redline.
Well, I did get a reply it was just buried in my mail box.
Originally Posted By: Dave @ Red Line
Ben,
Thank you for contacting Red Line Oil, the Race Oils and Motor Oils contain the same base stocks, the differences is the additive packages being optimized for each intended use.
Regards, Dave
Red Line Oil
So there you have it, the race oils and street oils have same amount of esters. Which makes sense based on what I've heard from RL in the past, that they use the max amount of esters that is considered optimal for motor oils and cut it with a PAO additive carrier.
Ben,
Regards, Dave
Red Line Oil
