dnewton3
Staff member
I think we'll all of the same general notion, but some of the nuiances may never be known, if one or more parties has something to hide. I am NOT blamining anyone in particular; I am pointing out that some of this might be akin to the "chicken and the egg" issue, and those that might suspect they are at fault, may not fess up to the fact.
Without a doubt, dirt ingestion the a major contributor, especially after knowing the crankcase contents. But, fuel might have been the lingering death, as already noted. Fuel contamination cannot cause an air leak, and air leaks cannot generally cause fuel leaks. Two things were wrong here, but one did the deed before the other. These are, after all, individual contributors that each could have been the demise seperately. Oddly, they happend together. Very much like the gunshot/heart attack scenario.
The reality is that this engine suffered from both chronic (fuel) and accute (dirt) contamination issues. I don't know that I have the ability to acertain which one truly killed the beast first, although I suspect it was the dirt. But if dirt had not got it, the fuel eventually would have most likey; 14% is simply bordering on true negligence.
I don't know of any operational manaul (owners manual, shop manual, etc) that doesn't state to check engine oil at least daily. If the owner/operator had pulled that dipstick on a frequent basis, I cannot believe that something like dirt and/or a overwhelming fuel smell should not have alerted someone to major issues being present!
What is very likely NOT the cause is poor reman work; not in the sense of the machining work. Perhaps the blame lies in either the set-up after re-installation, or perhaps it lies with the owner/operator in that they didn't do daily checks. This is EXACTLY why people should check oil level and conditions on a dialy basis for expensive equipment. You don't need a UOA to tell you that the oil on the dipstick looks like mud, feels like sand paper, and smells like home-heating-oil ...
I understand that someone is going to be very unhappy with the overall analysis and synopsis, but that is the reality of it. Some person or persons didn't check the set-up, and someone didn't do daily checks. This condition should have never gotten to this point. I see this as blame being on multiple levels. The reinstallation work was likely flawed, possibly causing an air leak and defintely causing a fuel leak. But, if the owner/operator had been doing the PM checks, the conditions were likely to be found WAY before this happened. My apologies if this comes off as blunt, but sometimes the truth is not popular.
