I'm curious about the evolution of gear oil.
I have several Farmall tractors from the 40's and 50's. The original manuals call for 90w oil in the trans/rear. In the mid and late 50's IH came out with the Torque Amplifier (basically a gear splitter utilizing a planetary gear set and wet clutch that preceded the transmission) and lighter universal trans/hydraulic fluid was born to give better performance. The transmission and final drive were still the same design however.
I've been using GL-5/MT-1 as a replacement in non T/A applications but I'm a little bit concerned about formation of corrosive elements due to moisture and the EP additives required of GL-5. The shared case for the trans and final drive tend to collect moisture over time due to surface area available for internal condensation, even when stored out of the weather. Some are using the UTF fluids with no obvious ill effects, but there are no wet clutches or brakes or shared hydraulics on the earlier tractors that would make it a requirement.
Except for the reverse idler shaft, All shafts run on ball bearings. The reverse idler uses steel backed bushings. The gears are sliding type, straight cut. R&P are bevel straight cut.
I'm wondering where 90 weight refined in 1950 would fall on GL scale we use today and how it would compare even against motor oil in comparable weight and additives. What would be the viscosity of a typical UTF type fluid? And why is UTF always labeled as such and such "fluid" instead of "oil"? Is there something to the nomenclature? Would certain motor oils merit consideration as gear lubricant in this case?
