Originally Posted By: unDummy
If you're lucky, you might be able to find the Pennzoil 75w90 GL4 gear oil.
Nissan, Kia, & Hyundai dealers have a GL4 75w85 manual fluid which they are using in place of the 90wt gear oils.
Redline MT90 or Amsoil MTG can be used but you pay a little more for the best fluids.
And, some of the local autoparts stores have the 85w90 crc, statlube, or coastal gear oils.
I've used GL4 marine gear oil for plenty of years in several transmissions. So, you local marine supply might have some bottles of various GL4 lower end lubes.
Thanks! Oh I did buy the Coastal brand before, but it was a combo GL4 & GL5 app. I only used it to replace the 1/2qt that spilled when I took the axle out to replace the control arm on my vehicle. But again, I can't use it at full because It can "trash" my MT. I don't know why it is difficult to find a GL4 only app. at the auto-parts store, why is that? Thanks.
