For general interest, I wanted to update my Oct. '09 post about filling the trans of my Ford 2810 tractor with a mix of Amsoil and RP 75W90 GL5 syn gear oil. I've been using the tractor through this WINTER (caps because it's been a cold one) for snow removal and that's where I previously had some trouble shifting.
Good Initial Results
The original '80s-era Ford spec was for the equivalent of a 85 grade gear oil/40 grade engine oil... a "Universal Tractor Fluid" (UTF) which could be used in engines and gearboxes and was popular in those days. The stuff that was in there (likely NOT UTF) seemed very thin and I suspect it was THF installed at the dealer some years back during a repair. The bottom line was that the tractor shifted poorly (in the context of a crash box) whether hot or cold. Espcially cold (a surprise since the THF is a 20 grade).
In a nutshell, hot or cold, the trans is now shifting GREAT! Light years better than before! Even the first shift of a zero degree F start is nice and smooth. Barely more difficult than on warmer days. The Amsoil and RP appear to be playing nicely and this turned out to be a great way to use up some old gear oil stock.
