That's exactly how I see the issue. The GM IMG might have been the least compatible with OATs being a silicon with a nylon carrier. But silicon is not the only gasket material that is not resistant to OATs, and I bet GM is not the only one that has used gaskets that are non-resistant.
Although in GM' case an OAT was factory filled and recommend yet still incompatible, I'd think that most any equipment made after '05 FF with an OAT containing coolant would be compatible. But to be safe I would not try to back-spec older equipment with an OAT coolant other than G-05.
..concerning ford or chrysler, (model yr 2005 onwards), it would seem that "havoline" is also taking the same position of no "back specing" for their new tri-oat formula..all other cars get dexcool or the low silicate green
http://www.texaco.com/yourcar/havolinecoolants/findRightCoolant.asp
That's interesting. Texaco recommends Green in everything and all years except for 95 up GM (Dexcool of course), and ~'04-up Ford and Chrysler (Custom Made). I don't see where it says Custom Made is a tri-OAT? I figured it was G-05 being a silicated hybrid, but it does mention it has carboxylate inhibitors and I can't remember if benzoate, which G-05 has, is considerd a carboxylate or not but I don't think it is.
Anyway Havoline is recommending Green for most all models and years.
..Maybe they are playing it "safe" with the "green" recommendation..at the moment, I will say that I screwed up by mentioning "tri-oat" because I can't find the "link" to that reference at the moment..hopefully later..anyway the ingredients listed in the MSDS are the same as JD II..I find it interesting that the "custom made" is not back spec'ed in the same way as the G-05 was for ford and lincoln, until 1999 or 1998...But is the G-05 of present day still the same product as in 1995..I have my doubts since it hides it present formula behind the wall of NJTS#s
What it says to me is Havoline acknowledges that OATs may not be compatible with applications' gaskets that aren't FF with the OAT coolant. They are saying what I've been saying, to play it safe and not put OAT coolants in older vehicles.
Also it is up to the engine manufacturer to verify and backspec coolant. Havoline is not doing it. So far, like you mentioned only, Ford has back-speced G-05.
Forget about MSDS. As we seen you can go through various MSDS for the same coolant and find didn't ingredients. the MSDS do not list all th ingredients and neither doe the ingredient list on the coolant bottle. G-05 is a standard formula and they all contain the full formulation.
