Originally Posted By: jessh
What happens if you put to much additive in? The clutches just dont lock up as good as they should?
That and it can cause viscosity problems with the lubricant. Check your owners manual about how much to put in and use that number, but the generic application is about 3-oz per quart of lubricant. My book shows the 10.5" rear axle holds 7 pints, that would be a skosh under 6 oz. I'd likely add it a littel at a time.. maybe half a dose, then try it (the figure 8 routine).
